Hi Guys,
You may remember me from my 3.0GHz SL6WK L349 OC'ing posts and now i'm back to share some OC'ing results with a 3.0GHz SL6WK L351B158 03/02/04 CPU (30 Caps) which is from the same batch as Fuzion's brilliant 4GHz chip.
I got it about 10 days ago from PCSupplySource via a friend and so i've had a fair time to now play around with it and see what it has got in it.
Just to remind everyone, here are the most important specs of the rest of my system:
ABIT IC7-G V1.1 Motherboard, 1GB (2 x 512MB) Mushkin PC3200 2-2-2 Special DDR RAM, Sapphire Atlantis ATI Radeon 9700 Graphics Card, Thermalright SP-94 w/ Vantec 92MM Tornado Fan on Vantec Fan Controller, Antec True Power 550 Watt Power Supply Unit and 2 x Maxtor 120GB SATA Drives In RAID 0 Configuration on Intel ICH5R
Well, at the moment it isn't a wonder chip at all, though that may be due to the motherboard? or the memory? or the power supply?
Let me explain:
Well, you may remember that with the L349, I couldn't get it stable past around 240 - 244 FSB and anything past that, the system would either fail P95 (Dual Instances) or just reboot (the HDD's actually powering down as well but the system rebooting).
I tried everything in the BIOS, stripped the system down, tried pretty much everything I could think of such as VCore, VDIMM, AGP Voltages, Memory timings, GAT settings and so on but just couldn't get it past 240 - 244 FSB stable - at around 1.65V - anything past that, even 1 FSB and the problems listed above would start.
The temps were very high (around 70 degrees celsius) though the IC7-G reads about 10 degrees celsius higher than the actual temps and though I tried two HSF's it was the same problem eventhough case cooling was ample and very good.
You guys suggested a change of HSF as a good way of going and I bought a Thermalright SP-94 - an excellent drop in temps, but still a no go anything over 240 - 244 FSB but well worth it just because of the cooler temps.
This L351 seems to exhibit the same behaviour for some reason - I can get it to 250FSB (It posts and gets in to XP with as little as stock voltage and runs fine (Not P95 stable), but regardless of VCore which i've taken up to 1.675 and regardless of relaxed timings, VDIMM, AGP Voltage, GAT Settings and so on, though it is Dual Prime95 Stable for the short time i've managed to test it so far, I get BSOD after BSOD in XP, Internet Explorer crashing, Explorer Crashing and so on.
0x0000007e, 0x0000007f, 0x0000008e, 0x00000024 and so on - the system just BSOD's, the power to the HDD's cuts and the system just reboots.
I've stripped the system down, disconnected Optical Drives, tried the HDD's on both the Intel ICH5R and the Silicon Image Chip, got rid of PCI Cards, played around with all the BIOS settings imaginable, tried a different PSU, tried 1 stick of RAM in all the slots and alternated them, changed the TIM on the NB HSF to AS5, as you can see, pretty much everything.
The CPU feels like there is more in it - it posts up to 260FSB and a little bit more fine.
I've run Memtest for several hours and everything is perfect, no errors, no nothing - but load Windows and the fun starts, BSOD'ing here, there and everywhere.
I had some Corsair PC3200 XMS and that did the same thing so I don't feel it is the memory, PSU i've tried a different one and same problem so I don't think that is the problem, second CPU now that i've tried with similar behaviour - perhaps i've got two CPU's which have roughly the same limit, motherboard - could be the problem I think.
Any ideas guys on what the problem could be?
So far then, if I could get it stable at 250FSB it would be brilliant but so far even that isn't happening - not BSOD'ing at the moment, but i've had to set CAS to 2.5 which I shouldn't need to do as the memory is rated to 2-2-2- at 200MHz, it passed Memtest fine at 2-2-2-5 but having problems.
Temps are on load around 55 degrees celsius which includes the extra that the IC7-G reads.
At the moment then, I would say average for this chip - it seems to have more in it though, maybe....
Fuzion, it would be cool to know how your second L351 does buddy so we can compare
Still playing around with it though so who knows.
Let me explain:
