- Dec 30, 2000
- New Jersey
That's what they claim at least. So does this mean I can use a normal computer PSU?! I could get a decent computer PSU pretty cheap.
AMDgeek (May 09, 2001 10:22 p.m.):
unless you have a monster power suply the 12 volt suply on most can only suply 3.3amps and the pelt will draw more than the power suply can handle and coook the power suply
Kryten (May 09, 2001 10:45 p.m.):
Check your label again AMD most PSU are lot higher than that
more like 13.3A, I think off the top of my head mine is about 16A
My calculations says you will require 13A for the pelt alone.
DE (May 10, 2001 11:34 p.m.):
allelectronics.com
500w psu = $25
jay (May 11, 2001 10:56 a.m.):
you can get 24V from a standard PSU
as voltage is potential difference....
a PSU has a +12 V and a -12V
is it just me or does anyone else also see 24V
