The Coolest said:Yea and don't forget a shot of WCPUID/CPU-Z
CrashOveride said:
did you mean GCPUID?
JungleMan said:I think he means WCPUID also
mrspec3 said:VDD was 2.1V
Vdimm 3.25V
3dmark....I don't do it. I have a GF2 MX400 so there is no point. I can play games so I figure its the same thing. Problem is though that after 10 mins or so sound usb and nic all die. I think the SB is over heating right now still
NB is cooled with a thermaltake SK-6
hitechjb1 said:
Put a passive heat sink on the SB with good air flow over it would improve stability at high FSB. It may even solve your stability problem. Adding cooling to SB (for sound and HD) is even more important since it usually comes with no cooling, and NB at least has some default cooling.
Pic for passive heat sink for SB cooling (on page 1)
I did that and it helps stability, though my FSB is not as high as yours, only around 210+ MHz at default chipset Vdd of 1.53V (measured).
Please try it and let us know, because that may be important for attaining stability at such high FSB (250 MHz as yours).
Which method of chipset set Vdd mod and Vdimm mod are you using?
Do you mean ThermalRight SK-6?
hitechjb1 said:mrspec3:
Is this a new setup using NF7-S rev 2? I thought you had a NF7-S rev1.2 w/ A2 NB for the 250 MHz FSB, with 2.1V chipset Vdd and 3.25V Vdimm.
Would the SK-6 over the NB too big and interfere with the air flow for CPU cooling.
Wow is that SK-6 held on with just a zip tie?mrspec3 said:
Yes it was the thermalright sk-6...it was late
Here is a pic of my current cooling setup. I am putting the old NB cooer on the SB later
v8vega350 said:there is a 1.4 bios out for the nf7 2.0 that will let you go to a 300 fsb just thought i would let you know it is beta though
