I just picked up a 650 TI OC video card, plugged it in, plugged in the vga port from the video card and tried to boot up. The system boots up but the screen stays black. Nothing ever appears on the screen but I hear the system sound when windows 7 boots up.
Note: The palit GEFORCE GTX 650 TI "OC edition" didn't appear to need any power cables connected to it, so it is just stuck in the slot and screwed in. I'll double check if it requires any external power other than what is coming off the rail but i doubt it.
Things I've tried:
1. Setting bios to "PCI Express"
2. Trying DVI on the video card instead of vga
3. Disabling onboard adapter through device manager (Screen changes to a horrid resolution) Then I restarted using the VGA on the video card (same thing with b lack screen)
4. Poped in the driver CD and tried to install driver and it said something like "No driver compatible" (Now i start to think that the card isnt detected)
5. Went to device manager and see no device for the newly installed 650 ti card
So right now the fan is running on the 650 ti card but using vga or dvi i'm not getting signal. Tried the things above and it still isnt working, I don't even know if it is being detected at this point. Any suggestions?
-EDIT- Just seen that it does require a 6pin power connector. Found it hiding under the plastic cover plate
Now the only problem is my PSU only comes with 1 6pin connector which is plugged into my mobo. What is the next best solution other than buying a new PSU with two 6pin connectors? Thank you.
Things I've tried:
