- Apr 17, 2007
- British Columbia, Canada
- Thread Starter
- #41
I'm with OC1 on this, ZALMAN!!! I can't get enough of posting pics of mine
Oc1Kenube said:
thlnk3r said:Thats your STOCK score? no oc on the card, wow why is it so much higher then my 7743. I haven't benched since I changed some power connectors. Will do soon.
The settings I use in cs:s are High, High, High, simple relfections, low shadows, color correction on, no aa or af and vsync is off. HDR is also off. I dont think you'll be able to do the res I have unless you have a widescreen, its a acer al1916w 19", so the res is 1440x900...odd res So with those settings above it did 159fps in stress test.
Are there better drives then the nvidia ones? I came from ATI so nvidia stuff is new to me. The card definitely has potential.
thlnk3r said:Ah yes sorry meant "drivers" , yep those C2D's are smokin fast. I'm thinking about making a custom cooler for the card using a older P4 HS. I did it on my x800pro....helped out alot on temps.
Xymox said:Hi guys. I hope you don't mind me jumping in here for a moment. I have an EVGA 7900GS that likes to randomly leap the fan to warp zone 6. It especially enjoys firing up if I view a WMP movie, or even sometimes when I launch Trillian. I've tried Ntune, nVidia control panel and nothing is able to keep the GPU fan settings. So I'm assuming (like many others), it's a nVidia driver issue.
My question for you, if I was to purchase a VF900-CU to replace my stock fan unit, would this solve the very audible noise issue with my fan?
Thanks.
Thund3rball said:
3. To answer your question... YES! I would whole heartedly concur that a Zalman will be quieter than your stock cooler. I did not use the Zalman Fanmate controller so it is running around 2600rpm all the time and very quiet.
PS. I can't get Rivatuner to control the Zalman fan because it is not plugged into the video cards fan plug, it's in the motherboard 3 pin plug. But a fan controller or SpeedFan could probably control it.
thlnk3r said:I recently made some minor changes in my bios on my asus board to the peg link length ect, and my frames appear to be better in cs:s, I was dippen to the 50s in most maps, now I only get as low as 70-80...maybe its just me or it really did help out? ;P I'm very happy with my 7900gs
thlnk3r said:Apparently asus ( I might be wrong ) was the first to incorporate the peg link options in the bios.
Here's what I have mine set to:
PEG Link Mode - Fastest
PEG Root Control - Auto
PEG Buffer Length - Short
I don't know if these settings ACTUALLY helped but I noticed a difference on my setup, I also have my opty 146 oc'ed to 2.6 on stock voltage so that might of helped too I'm still in the process of changing the cooling on the card too, will post pics when I'm done.
Intelligent Overclocking Tools
· AI NOS
· AI Overclocking
· ASUS PEG Link
· ASUS AI Booster utility
