Nandro
Disabled
- Mar 21, 2004
- Wherever I happen to be.
I didnt remove mine specificly because people are having a hard time with the spacing, and i would imagine you need the right thermal pads to put it back.
ProBoner said:The pads didn't get damaged when I removed mine and are still providing very good cooling for my ram but I really screwed up the GPU because of not only spacing but more importantly the fact that I snapped one of the screws in the cooler
Now I can barely go over 670mhz core before artifacting... what's a good aftermarket GPU cooler for these cards? Preferably one that covers the ram too but I guess I can look for ramsinks too.
Nandro said:I have mine running at a nice stable 700/800 right now although I did clock it up to 725/830 for testing. I honestly think my MB dosent allow me to OC anything as well as it could on a good board which will be my next aquisition as soon as I can get this stupid tree to grow money instead of grapefruits.
Nandro said:Great Dan.... Just after I fried some memory and a MB... There is something inherently dangerous of people who have no fear of a soldering iron.... I'll be right there behind you....
Dan0512 said:Well, I just found another feauture that might be enabled with the flash as well. I can now control the fan speed with Rivatuner, which was available with the GTO BIOS, but didn't have any effect.
wundi said:Hey Dan, many thanks for your flashing instructions -- I am a proud new owner of a 7900GTX!
My main motivation for the flashing was to get control over the fan speed. Indeed in RivaTuner Hardware Monitoring three new graphs appeared, called "Ambient temperature", "Fan speed, RPM" and "Fan duty cycle, %". With the GTO bios I only saw "Reference fan duty cycle, %" which still remains at 100%, due to it being set to 100% in the firmware (according to Nibitor).
The graphs report a fan speed of 49.80% or ~1160RPM. However, no matter what speed I set it to in System tweaks, the speed won't change one bit.
Any ideas?
I did reinstall the drivers after flashing, and I have basic understanding of using RT. I like to set up the fans in my system to change in speed automatically according to monitored temperature. This worked flawlessly with my previous card, 7800GT.
For reference, my MSI card clocks at ~690/860 (haven't tested extensively and not at all with GTX bios). I'm using RivaTuner 2.0 RC16.2 and ForceWare 93.71.
Dan0512 said:No problem! Glad you could use it.
To control the fan speed, you have to go under the ¨low level settings¨ (customize right beside the pipeline/memory information) section, and you'll see fan section there.
wundi said:Woah! I wasn't aware there was such a "low-level" way of changing the fan speed. It seems my understanding of the software is even more basic than I realized..
Anyway, it works and I'm happy. Thanks again! I'll post in if I notice a change in my max OC due to the GTX bios, I'll have more time to test this weekend.
BTW, what ForceWare version do you recommend with this card? Ie. is it that the newest official, 93.71, is not the best (fastest) one?
Max0r said:^_____________^ would this apply to the GTX as well Dan?!??
electronpn said:Hi ! I have MSI NX7900GTO-T2D512E (flashed 7900GTX bios) 690/800 but my results are:
3DMark03 20100
3DMark05 9060
With the stock bios results were at 690/750 max stable
3DMark03 20600
3DMark05 9160
So looks like I gaind nothing with 7900GTX bios but it doesent matter. I wander:
Why do I get those results at the first time (stock bios) when your results are much much better. For example your results Dan0512.
PC I have : Gigabyte GA-K8NF-9-RH
AMD Athlon 3000 Venice 244x9 (2.20 MHz)
Kingston 512 cl 2.5 PC3200
Corsair 512 cl 2.5 PC3200
MSI GeForce 7900GTO (flashed GTX) 512MB 690/800
HDD WD 120 & 160 IDE 8MB
Samsung CD/RW & DVD/RW
Floppy Sony
Chieftec 420W
Modem Lucent 56K -----
P.S. I red something that it might be board like it has slower PCI-E. What do you think folks. Thank in advance !!!
Neural Net said:My card doesn't seem to want to play at high memory clock rates. Perhaps it's the voltage, I don't know.
I can run my GTO at 729/756 core/mem, that's auto optimising using Ntune, and rivatuner doesn't seem to want to work, do the two conflict? I'm running the latest forceware drivers. Anything higher produces artifacts. I also don't know how to up the voltage on the card, maybe that will help gain higher stable memory clocks?
I get 11220 in 3d Mark 05 though.
