- Sep 30, 2010
- Upstate SC
if you need to bend strange angles in solid line without using a mandrel bender, you can freeze very soapy water inside the pipe and it will bend without kinking.
I was talking more about 3/8 to 1/2'' copper hard line, that could be threaded for your fittings. Like I said though, I have no experience, and this could be a horrible idea.
Hmmmm... After looking back at your plans, maybe plan "A" might work out better after all?
Nice custom case.
Not sure if it's been asked already or not; only skimmed -- Are you doing your own welding on it? Don't think I've seen that very often / at all on a computer related forum, even in the alt modding section.
Glad you got the pump worked out. This is really coming together.
