A automaton Registered Joined Mar 16, 2002 Nov 27, 2013 #1 clcok speed 4330x 20 ? ram 1443 whwere did 1600 go bus speed 216 ht link 2384 dram frequency 722 nb 2384 does this all seem ok what happened to ddr3 1600 are the things I should change?
mtdewcowboy Member Joined Nov 10, 2012 Location Ankeny Iowa Nov 27, 2013 #2 You have it in auto so it downclocks Best to overclock everything in manual and set ram speed
OP A automaton Registered Joined Mar 16, 2002 Nov 27, 2013 Thread Starter #3 optimal mode mtdewcowboy said: You have it in auto so it downclocks Best to overclock everything in manual and set ram speed Click to expand... I am not trying to overclock its the optimal setting in eufi
mtdewcowboy Member Joined Nov 10, 2012 Location Ankeny Iowa Nov 27, 2013 #4 It raised your fsb so it drops ram speed Put ram in manual and set it to 1600 You may need to adjust timings to match ram
OP A automaton Registered Joined Mar 16, 2002 Nov 27, 2013 Thread Starter #5 wrent in bios eufi mtdewcowboy said: It raised your fsb so it drops ram speed Put ram in manual and set it to 1600 You may need to adjust timings to match ram Click to expand... went into advanced it says different speeds for ram 1444 then 17something no 1600?
mtdewcowboy Member Joined Nov 10, 2012 Location Ankeny Iowa Nov 27, 2013 #6 The fsb increases ram speed too that's why it lowered it so it won't overclock your ram
mtdewcowboy Member Joined Nov 10, 2012 Location Ankeny Iowa Nov 27, 2013 #7 Setting it to optimal auto overclocks your pc It don't do a very good job of it either
Johan45 Benching Team Leader Super Moderator Joined Dec 19, 2012 Nov 27, 2013 #8 Go into to the bios then hit f5 and it will return to defaults. Then you can set the 1600 again.
