Heres the Easy and safe way to remove the stock heatsink:
Take the card put it in an anti static baggie and place it in the freezer for 15 minutes as suggested.
Then take a credit card and place it up against the stock heatsink, then place a butterknife on top of the credit card and give it a small twist....The ATI heatsink will pop right off
Then use Arctic Alumina adhesive (especially if your affixing ramsinks) or Arctic Silver Adhesive to affix the crystal Orb or whatever heatsink your using.
Be sure to prep the gpu with Alcohol or Nailpolish remover that contains acetone to get the ATI adhesive off. (if you have steady hands use a razorblade and clean it up with the Alcohol or acetone)
