OK, I did some googling and doesn't seem you are alone with the board 8xxx series issue. A couple things you could try would be to update the BIOS and chipset drivers for the board. I'll have to check the card but it may be a conflict with PCIe gen 1 and 2
EDIT: I haven't been able to determine which PCIe your board is using. I'm going to assume PCIe 1.0. Early Nvidia PCIe 2.0 cards would quite often not work in PCIe 1.0 and 1.0a but wuld work in 1.1. Typically AMD cards wren't having the same problem.
Is this your main PC or just a project?
You may want to look at upgrading the MB to AM3. Your current chip would still work but you could update the Chip as well in the future to a Quad Phenom II etc..
Well that board is really near the end of it's life IMO. But I think you may have to look for an AMD card if you want to continue using it. I'm not 100% but I do think what I mentioned about PCIe is likely the root issue. That board is the M2n-MX se correct?
