Yes it does does make a difference! It's always good to know that I've helped.sulu said:Hi Gautam,
If it makes any difference, your post has helped me alot!
Ok...this still isn't making much sense, after reading it three or four times. The memory speed is derived from the total CPU clockspeed, right? So it needs a divider. In "CPU/xx" is "xx" the divider? Next, you say "Memory to xxx." I thought the memory speed was a result of the divider, and couldn't be adjusted...so when you say "Memory to xxx" is that something you set, or a desired setting? And the "multi to x" means...setting the CPU multiplier? Or the memory multiplier? Or the memory divider...ouch.What complicates what multiplier and HyperTransport speed you should use are the CPU/memory dividers. No motherboard allows you to manipulate them directly. Instead, they provide “maximum memory clocks,” or supposed HTT/memory ratios. Make no mistake, no such thing exists. The memory is derived off of the CPU speed, but it’s never made clear, and the dividers need to be manipulated indirectly. Also, CPU/mem dividers are integral only; there are no half dividers, so it’s advisable not to use half multipliers. Ok, what I just said probably doesn’t make much sense, so here are some examples of how to get certain get CPU/mem dividers:
CPU/5-8 - Set memory to 200 and multiplier to desired divider
CPU/9
Memory to 200, multi to 9x(if available)
Memory to 183*, multi to 8x
CPU/10
Memory to 200, multi to 10x(if available)
Memory to 183*, multi to 9x(if available)
Memory to 166, multi to 8x
CPU/11
Memory to 200, multi to 11x(if available)
Memory to 183*, multi to 10x(if available)
Memory to 166, multi to 9x(if available)
Memory to 150, multi to 8x
Thanks, appreciate it.Captain Newbie said:Bumpskies. Very helpful.
