Simply put, I'm working on a new build. I have something around a 2.8-3k budget, and plan on buying within a month or so. Here's the build as is.
Case - COOLER MASTER Stacker RC-832
CPU - Intel Core 2 Duo E8500
Per consideration, I'm going to be watercooling, so any more preferrable CPU suggestions would be welcome.
Hard Drive - 2 x Seagate 500GB 32M Barracuda 7200.11
Memory - G.Skill 2x2GB DDR2-1000 CAS5 F2-8000CL5D-4GBPQ Kit
Considering going with 2x2GB FB DIMM ECC DDR2 800 from Transcend.
Graphics - GeForce 8800 Ultra, 768MB PCI Express
I'm considering changing to the 8800 GT KO, perhaps going dual(if I get the striker), or waiting to see what the 9800X2 looks like.
Motherboard - Asustek P5K Premium WiFi Intel P35
Thinking about the ASUS Striker II Formula LGA 775. Thoughts?
PSU- Corsair HX-520 ATX
I'm thinking I'll need a much more powerful PSU, especially if I go full watercooling, this is post voltage calculations. Any suggestions?
System - Windows Vista Home Premium 64 bit (perhaps dual booted with XP)
Sound card suggestions would also be welcome, as well as good fan controllers/similar expansions.
Thank you in advance for your helps,
Ninth
Ninth
