phoenixofwater said:
SBeaver -
Yeah i have the samething... right now i have no power LED...
A quick and easy fix (allthough lame as hell
take a strong pair of scissors and cut the connector in your case for the pwr LED, the plastip connector that is, in half!
Do not cut the actual wires though, this way is much more easy.
Then your have two separate connectors that can then be connected to the header with no problem at all.
If I remember correctly the pwr LED header is att the top left two connector (well once you have the others on there are not so many free pins so you'll find your way)
Just connect the two half connectors to those two pins and make sure they are right with + and - since the LEDs need to be right with the cathodes and annodes.
And for the USB, if you want that I THINK that you can turn the USB connector on your backplate upsidedown and connect it, but leave 2 pins free which do not fit.
The data and ground pins might be incorrectly alligned then but that is easily solved with a little soldering.
I havn't tried the USB thing but it should be pretty easy.
If your a electronics guru maybe I'm just boring you right now but someone else might need the help.
