The problem is your A7V....its the KT133 right? NOT the KT133a. The KT133 chipset doesn't FSB oc very well....you probably can't get much over 108...I can't go much past 107mhz FSB. Pencil your L1's, and you should be able to adjust the multiplier.
I've gotten mine to 1.1ghz, (I too have a 900 Tbird), but it locked in windows, so I put it to 1066 and its stable, although a bit warm, 50C full load with a WBK38w/80mm Sunon fan and ASII.
Mike
