- Jan 12, 2012
Must be the clown gloves and the big red nose, honk honk.It is 'em big shoes you wear with your red-hair suit, that is slowing yore fangers down.
Hehehe.
RGzzzzzzzzzone...ster.
Hehehe.
https://www.google.com/#q=gelid+140mm+gamer+fan = Gelid Wings and bunches of them.
RGone...
did someone say weirdness???
look at this crud, a larkooler ???? who uses one of those???? I do of course...
what about a zalman resevator???????? when ghetto rigged into an antec 920, I'm all in.
this is my second 9x120 rad, in the pic, about to be 18x120, I'm in the south like you are and need all the help I can get!!!!
Buddy, you paid a price to be here, run what you like!!!!!
water blocks???? pick one you think is pretty, they are almost all real close in performance.
Bet that red wig comes in handy when you're benching outdoors Mr. CleanbMust be the clown gloves and the big red nose, honk honk.
Sure does keep the bald head warm, at least better then the moth does.Bet that red wig comes in handy when you're benching outdoors Mr. Cleanb
if I cared about looks I would have had a face transplant years ago!!!!
thank goodness she's blind.
she may kick me in the behind but my world just wouldn't go round with out her.
I tried lots of LLC and very little. I think the original pictures were taken with LLC adjusted to give me the actual voltage I wanted. I haven't really touched the machine other than turning it on and off to make sure it's working. Will be doing plenty of stuff after my liquid stuff comes in.
So yeah, mongoled, it's been a while since I've actually done something on that computer.
*sigh* At least I have this here laptop to do my bidding.
Interesting to note that when prime95 had priority of 10, I could've continued but, can't monitor those temps.
Could you list all your watercooling parts ?
On a side note, your in safe hands here, I know of some of the posters from way back, RGone in particular (hi dude ) from back in the AMDMB forum before it became PCPer.
These guys are real good dudes, helpful and funny.
Have fun!
You may want to look into getting a EK-D5 X-TOP or similar for your MCP655 as this will increases the flow and pressure at restrictive parts of your loop.Yep, Hopefully I remember them all!
CPU Waterblock - EK Supremacy Nickel Plating on the copper
GPU Block - XSPC Razor R9 290X + the Backplate
Rads:
Triple 120mm XSPC Triple-fan Black w/ Corsair SP120
Dual 140mm but I can't remember it's name because it swapped out at the last minute. w/ GELID Fans (They aren't the wings, but they have nice static pressure.
Monsoon Series 2 Bay Res with an MCP655 PWM version pump, (Attaches to the back of the res)
1/2 x 3/4 Everything
A small chipset fan for the back of the mobo (Thanks Johan)
Everything else in the package is aesthetics and acoustics.
And yes. These clowns are interesting AND entertaining.
EDIT: Also liking that new Corsair 250D. Might build a Kaveri in it.
Was a while ago when the FX8350 came out that I was disappointed with my results primarily with the cooling / temps. Here is a thread I put together when I was working out the details. Take a read and maybe something in there can help. I was able to shave off a good 20*C in my temps.
http://www.overclockers.com/forums/showthread.php?t=715371&highlight=bassnut
