- Dec 6, 2009
I just built a new box...
Asus M4A79XTD MB
AMD PH II X4 955 3.2ghz
Sunbeam freezer with AS5
Saphire Radeon 4890
4gb Gskill PC 1600 DDR3
1 TB Seagate HD
Antec 300 case with extra fans (all air exiting the case is cool)
500w Thermaltake psu
After installing Windows 7 64bit I installed all the drivers, flashed to the latest bios (using the asus flash gui), and installed AMD overdrive. CPU temps were 38c idle, 43c load. GPU was 62 idle.
I let the machine run overnight, and it seems pretty stable (was able to play a few games ok). However today I tried to run the "Auto clock" option in AMD overdrive and it ended up crashing my machine (auto reset).
It started out ok, before the crash the first thing it did was change my cpu multipler to 16x (how does the cpu multipler relate to raw ghz/speed?), then it started to up my "CPU clock" from 200mhz to 201, 202 ect... This went on for about 10 minutes till it hit 205 where it auto reset my machine .
I was told this processor would overclock very well (up to 3.8 or evern 4ghz), and my temps look fine... so whats going on? How are things exploding so fast?
Only two things I notice as odd - on the Status - Board Status screen my voltages look off (12v is 1.8v, 5v is 2.8v, and 3.3v is 1.79v). The voltages look fine in bios however. Also my ram is showing as 666hz frequency, is this right for THIS type of ram...
http://www.newegg.com/Product/Produ...-Memory+(Desktop+Memory)-_-G.SKILL-_-20231193
Thanks in advance for any help!
Asus M4A79XTD MB
Saphire Radeon 4890
1 TB Seagate HD
