- Jan 19, 2004
- Tennessee
I've got an Antec Twelve Hundred case with a busted fan. One day, the 200mm "Big Boy" cooling fan at the top fell off of its mounting directly onto my video cards, which didn't do any damage but did successfully scare the hell out of me. I left the mounting in place at the time, as I have yet to find a replacement.
The "Big Boy" is available, but not with Blue LEDs. It's also not the standard "circle" shape, and has flat edges:
Honestly, I'd like to go with a fan from a different brand, as I've heard this fan was meant to be mounted vertically anyway, and thus gravity's role in fan cohesion is higher. The problem is that no brand seems to scream "Yes, I'm compatible", no matter what I look up. I've heard about people getting standard smaller fans and just screwing them into the fan grille, but I don't want to do that. I'm wondering if I can use a standard fan here (without cutting edges off) or if I can use something else?
Edit: By the "busted fan" I mean the actual fan blades and central hub fell off of the motor and landed on the cards. The mount and motor did not fall. This is why I'm trying to avoid the same fan .
