- Jun 30, 2004
- San Antonio, Texas
ok folks I'm running 19 fans 18 120mm and a single 140 in my BIG *** CASE. I'm looking at the Auaero 6 lt but cant find any in stock anywhere. I want it inside my case as I do not have any ODD bays available due to rads. Anywho this was upgraded from 8 fans that ran happily on my phanteks fan hub but well its limited to 11 fans and I now know why lol. Nutshell I added a 3rd 360mm and put them all in push pull so now 3*360mm rads 3rd rad covers ODD bays.
like I said I'm looking at the Aquaero 6 LT cause its designed for in case setups. I can find the XT and Pro's in stock at PPCS. Question is can I remove the ODD bay mounting parts and screen from an XT or Pro and make it like a LT?? More inline for the pro as its like 30$ cheaper and only diff from XT and Pro is touchable screen and a remote. I'd truly like motherboard control over any option but I'll suffice with software control.
Fans are Aerocool Dead Silence Black 120mm 18 of these
Rated Voltage 12V
Starting Voltage ≧3.0V
Rated Current 0.3A
Power Consumption 3.6W
Areocool Dead Silence Black 140mm
Rated Voltage 12V
Rated Current 0.39A
Power Consumption 4.68W
This is incase ya have another suggested option for a controller. I've also considered the NZXT Grid V2 but I'd think 3 of them trying to run the software might be confusing to it.
Current specs of rig are.
Asus Z170-A
6700K
Titan X (non Pascal)
16Gb Kingston Savage
1050 watt psu from Seasonic
M.2 256 Intel drive
1tb samsung 850 evo
8TB seagate hdd
BIG *** CASE
Rated Voltage 12V
Rated Current 0.3A
Rated Voltage 12V
Rated Current 0.39A
Asus Z170-A
6700K
M.2 256 Intel drive
1tb samsung 850 evo
8TB seagate hdd
BIG *** CASE
