- Mar 26, 2008
- Southern Ontario
Edit it's a 760 lol ####
Happy holidays guys I've been steady folding on my 7770 and quad core ATI getting about 12k ppd. I've moved the 7770 down a slot on the motherboard and added the Nvidia in. I installed drivers and I can even see the card on msi afterburner. I have the monitor plugged into the new Nvidia. I can't seem to see the card on the folding at home configuration screen. It shows the 7770 ATI but no Nvidia. How can I fold on all these pieces of hardware.
Cheers
Eddy
##EDIT##
So i found the guide on the F@H website and im stuck at this point:
Vista/Win7: C:Users[username]AppDataRoaming
Note: This folder is usually hidden so you may need to type the whole path in the address bar or to enable the option to view all files and folders.
Once you’ve located the directory, copy the folder called Folding@Home-gpu and paste into the same location. Rename the new copy by cutting the “Copy of” off and adding a 2 (or more for extra cards) after the directory name. You will need to repeat the same steps if you have 3 or more GPU you want to use. Here is what it should look :
on my machine i have windows 7 pro and im in c: users\eddy\appdata (this is a hidden folder)\roaming and i see two f@h folders one is FAHCLIENT and one is Fahmon (monitor i take it)
I dont see the Folding@Home-gpu like the guide suggests any ideas? thanks!!
Cheers
Eddy
##EDIT##
