- Sep 27, 2003
- Thread Starter
- #41
thanks, but not sure if i wanna make my case an aquarium. (you know i mean no harm)... that's nuts that you did 4 yrs... so what was it that you had in there exactly... purpleares350 said:that is strange. my old system was running for 4 years, never had it cleaned through, just topped it off. that was not pure water obviously, it had some purple colored antifreeze in it, and the tubing was blue(though not opaque).
after 4 years, I was suprised when I opened my water block and found it in 99% new condition. some of that grey corrosion, but nothing severe. it was an RDX block or something, little acrylic thing with tiny maybe 1/16" holes to force the water through, and they werent clogged at all after 4 years.
if you really want clean water, just get an inline UV light. their made for aquariums of course, and they will kill absolutely anything in the water. nothing will survive. of course their probably 50-100$ atleast, gotta swap the bulbs out occassionally(6months-1year). but it will certainly solve any bacteria growth.
of course, with pure water, you need to think about your materials, copper and brass or aluminum or whatever will cause some nasty corrosion without additives. but thats another issue to address or not depending on your setup.
Nebulous said:Yup, still using most of the stuff I got from you. I used a plastic type of brillo pad with a slim stick to push all the crap from inside the tubing walls. Took a few passes, but got them clean.
The stuff I got from you still has the "stain" inside the walls that won't come out, but the newer stuff I have with it is still clear and clean, that's how i know there isn't any crap growth.
Been trying to get a few feet of new tubing just to redo the lines. lemme know what you're getting. I'll chip in for the xtra .
I gave you tubing once or twice? The first time I used the MCT fluid from dangerden (32oz bottle)... the second time was distilled and anti-freeze mixture. The 3rd time (this time I just cleaned) was distilled and Swiftech HydrX...
Maybe it's my rad...??? Maybe it's NOT bacteria? I mean, my tubes ARE cloudy...
Neb, let me know where you got the stuff to clean your tubing... I may spend the time cleaning them up this time around... I have new tubing to use, but maybe I'll clean these and do a swap every once in a while.
... still trying to figure out what mixture I wanna use... I'm probably gonna do it tonight cuz last night it got late before I could finish.
