okey , have you put something new in it ? like gpu/ cpu/ anything ? have you hold power button for 10-15 sec AFTER EVERYPOWER CABLE AND PSU IS OFF? when u took out cmos bat? or u could burned the mobo or comps becuse you took out battery with power still in pc , and you need to have like " duracell or some trusthworthy 2032 battery not a cheap amazon/ ebay/ **** , take everything out with battery left all out 10-20 mins, if u have biios flashback usb , use it WITH USB and follow blinking to know when its done and rename bios files , try to use the oldest monitor connection " VGA / DVI / " IF u have a intregated GPU on cpu , try that first then your own GPU card, CHECK CPU PINS IF SOME IS FKED UP OR BROKEN, 1 little fking anoying cpu pin can make a whole system unstable becuse non of u dont know what that pins for it can be for RAM/ GPU/ CPU / south/north bridge and when it happens the pc dont know what error so it just blame " VGA led code " when it can be something else, it dont get connection to the whole system so random error will show up after a while, i had z77-gd65 mobo , MY ONLY WAY WAS to start pc when i had screw driver on jumper pins on mobo after i hit power button , both bios a/b was bricked, and cpu pins worlds most top 1 PC builder cant solve it if it pins who are broken too much, but why u have 8 GB ram ? minimum 16gb - 1600 mhz clocked , i have a INTEL GEN 1/2 cpu and ddr3 i know " BUY NEW IDIOT" yeah , but i only play dota2 and stable 120-140 hz/fps with just 90% optimize windows works , and minimum OC , but i BET I have faster startup from hit powerbutton to get inside windows than many of you all even if u have 10 -15 year newer pc system and PARTS ;D try that guys , but broo u need to test everything u can , i guess your gpu/ memory dont recongnize by system nd 99% sure that u once atleast before this have tried overclock memory and cpu / gpu
and dont think once it can be that who is " BOOT ERROR MESSAGE " , TURN OF ALL C-STATES / POWER SAVINGS SETTINGS, TURN OFF INTEL SPEEDSSTEP SIMLAR THINGS IN AMD, settings on. INSTEAD - OR IN FUTURE - USE " chris titus - WINUTIL " DEBLOAT + SPEEEDUP WINDOWS, "
USE THIS GUIDE FOR OPTIMZE DELUXE YOUR PC " fr33shy Windows Optimize guide for win10&11 " FOLLOW AND LISTEN TO 110 % " or u will fail,
MOST IMPORTANT FOR FPS / GAMING / INPUT LAGS/ slow/ IS OPTIMIZE WINDOWS WITHOUT - BOOSTER FANTASY programs , DISABLE WINDOWS DEFENDER " DELETE " U SHALL HAVE 60-70 MAX SERVICES WITH WINDOWS + YOUR OWN MOBO DRIVERS / gpu / lan / ssd / drivers and serivice ,/ USE ALL CPU CORES ON 100% 24/7 / IN the fr33shy guide u get a power performance scheme from BITSUM , USE IT, and IN MSCONFIG - advanced - STARTUP in a box u find numbers of all your threads/CORES click on highest number - apply - ok, IF U HAVE 8 GB RAM GO to store buy 1 more exactly same ram or 2 new minimum 8x2 gb ram or 4x4 gb ram / VOTE FOR KINGston hyperX minimum 1600 mhz , or gskill / vengance ram , your SSD drive dont even work normal with windows power scheme and power saving settings on intel/ amd cpus , its made for go fast, TRIM SSD, DOWNLOAD ALL DRIVERS FOR MOBO / CHIPSET/ LAN / WIFI/ GPU / EVERYTHING BY U SELF , SATA DRIVERS, if u have intel or "msi / gigabyte / asus SATA OWN PORTS , ALWAYS USE INTEL SATA DRIVERS AND PORTS , ON YOUR "C:\ drive INSTALL ONLY COMPLETE CLEAN WINDOWS WITH USB , AND WITHOUT INTERNET ONLY USE LOCAL ACCOUNTS ONLY INSTALL DRIVERS AND GAMES / SYSTEM , ON THE OTHER ONE U HAVE AS STORAGE DRIVE, ANTIVURS ONLY ESET INTERNET SECURITY / SMART , ALL OTHER IS CRAP AND SLOW AS FK; and worst thing is THEY HAVE VPN HAHHAHAHAHA, FOR WHAT, your info get leaked like facebook with those and just slow down, WIn defender just destroy your pc , windows update ONLY ONLY SECURITY UPDATES REST OF UPDATES POST for a few month/years , disable all services u dont use or system need for that u doing , IF u have " 120-140" HZ / FPS MONITOR , DONT HAVE FPS IN GAMES OVER YOUR MONITORS OWN MAXIMUM HZ on that resolution you have , becuse u will get input lags, and fake fps;D . when someone even with 15 year later pc system then me start pc and logged in to windows and all startup done before 15 seconds just call me ;D then i can tell u that you are deserve to have a pc for 1500$$ , just for saying im on socked 1156 - intel 860 i7 3.1ghz + )- ddr3 kingston HyperX (DUAL-CONFIG)1333mhz OC(1600-1650)mhz / radeon 480rx GPU from Asus , with 580 firmwere / drivers , UNCLOCKED , JUST HIGHEST BITSUM POWER Scheme , and ALL POWER SAVINGS OFF. 100% OF CPU ON ALL CORES/THREADS SAME EVERY SECOND, network adapter (configed) to maximum all network speed for game and system , kingston ssd 480, with all my configs and tweak/ optimize it work like a USB drive in my old system it is a drive but mobo/windows think its usb simlar drive, my ram settings in bios " not UEFI " iS IN xmp profile with " extreme mode " on a ram setting, " combo with power scheme , your problem is that u neeed to try all step with simlar errors , and look into their solotion / guides to fix yours but first reset cmos battery / ram / dont maximum overclock ram or cpu , / reseat cmos battery and pc parts , before connect cables into mobo and psu - find a screwdriver hold it on cmos jumpers both when battery is in place for 10-15 sec, or if u have cmos button hold it , without power or your pc burns, now if u get screen, goto bios RESET IT DEFAULT AND REINSTALL PC AND START FOLLOW GUIDES
