- Jan 12, 2002
both are made the same week at the same plantJimbob7 said:Which is the newer chip in terms of when it was made?
Scott.
7514 - y2005 week14..
Scott.
lowfat said:And you can adjust the multi fine? I couldn't when i tried using that bios.
Jimbob7 said:Very strange! See what it can do FSB wise. My Dothan doesn't like much over 2.7 even there it's a bit flakey. But it can handle a nice FSB as far as 875 chipset goes.
Scott
Sjaak said:I also put up some pics of my rig up and running, see here: http://www.ocforums.com/showpost.php?p=4075203&postcount=1045
BrianH2O said:There has been many discussion about this. It seems that the bios applies the FSB before it applies the VCore changes. So, you are trying to apply the 250FSB to stock vcore which does not work well.
What I do is bo0t at 10 x 201 then use SetFSB from the startup folder to boost my FSB to 275. Pretty transparent actually.
