Hi,
I am going to buy components and build my first pc. I live in China so i'll be ordering everything from newegg here. I would just like to know if the following components would go well togther. Basically it will be a gaming computer and my only real intention is to be able to play battlefield 3 at absolute max graphics (and starcraft 2).
Please, if you see any component that is overkill for my needs please suggest something else. It is purely a pc for gaming. As i understand the gfx card is the most important component, and i'd be happy to cut back on other components if they aren't really necessary and spend more on the gfx card. A gfx card that is good at 3D is also quite important as my gf will enjoy 3D movies on it. Prices in chinese currency, 1.00 RMB = 0.157456 USD. Thanks for advice! This is what i have come up with:
Graphics card: ASUS ENGTX560 DC/2DI/1GD5 1G
Graphics card
1639rmb
Cpu: Intel i5-2500k - 2.9GHz
Cpu
1259rmb
Mobo: GIGABYTE Z68X-UD3R-B3
Mobo
1399rmb
Mem: AVEXIR DDR3-1600 4GB x 2
Mem
165x2 rmb
Cooler: Noctua NH-D14
Cooler
599rmb
or Corsair H60
Power: CoolerMaster GX750W
Power
719rmb
HD: WD 500G WD5000AAKX
HD
699rmb
Case: CoolerMaster RC-430-KWN1
Case
269rmb
Totally 1100 USD. (Basically this is my budget too). While most things are cheaper in china, computer hardware isn't one of them.
If 750w is too much power please let me know, or if a cheaper mobo is suitable please let me know. I'm a noob so i'm not sure if this is a good case either, but i'd like one with decent airflow and which can fit the above components... as i understand the case i selected above is a full case so quite big. Also i will be overclocking the cpu just for the sake of it i guess, and might in future get another gfx card for crossfire so need a mobo that can accomplish these tasks.
Graphics card
1639rmb
Cpu
1259rmb
Mobo
1399rmb
Mem
165x2 rmb
Cooler
599rmb
or Corsair H60
Power
719rmb
HD
699rmb
Case
269rmb
