- Aug 24, 2007
while they talk about tech the only thing it is a chip/mem width change. the size has nothing to do with the video card. its the resolution he will be running, if he is running aa/af the 8800GTS 640mb. has a wider memory width then the 8800GT/GTS 512mb, the difference is that both with out aa/af preform the same. the 9600GT is a good card for those with out much $$ to spend. as your talking 9600GT =$145,8800GT/GTS 512mb=$200-225. people dont list the memory for the 9600GT since it only comes with 512mb 256bit vs others. since with the 8800GTS you either get a 256bit/512mb or the 320bit/640mb or 320mb/320bit cards. the 8800GT only comes with 256bit 256mb/512mb cards.
8800GTS's
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130082
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130317
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130337
now just depending on how much he is willing to spend. i would say look at 9800GTX or a 9800GX2. if he doesnt mind ATI the 3870X2 is a good deal vs where it was at when released. there are options the problem is not knowing the price that person is willing to pay.
ati 3870X2 (not much more then the 9800GTX)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102723
9800GTX
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130339
9800GX2 (basicly 2 8800GTS 512mb/256bit cards already in SLI)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130338
sorry but i read it a few times and prolly blind but i didnt see a price listed for a GPU. no with the GPU's i listed last the guy is prolly going to need a new psu in that dell rig. if he doesnt want to go that far stick with the 8800GTS 320bit or the 256bit cards.
Wait, what? Are you saying the 8800GTS-640 beats the 512 in ANY way? Tough to tell, the post seems a little but anyway, don't even consider a GTS-320 or GTS-640. They are old and not worth it.
