df0xyd said:Ya... well, you see, I don't trust water.. 1 leak and BAM your $2000 commputer is gone, ya know?
Also, If I wanna overclock, I need to make sure I have ample enough cooling for my GPU, CPU, and RAM.
A properly done (not even well done) water cooling system won't leak. Also thats why you leak test. Once a system has been leak tested to the point where you're sure its sealed up (usually a day straight for the neurotic, personally I do it for as long as it takes to bleed my loop + 15 minutes ), there's no real chance of it deciding one day to wet down the whole system. In addition water itself (as in the distilled water we use) isn't conductive. The minerals in tap water are what makes it conductive.
