Before I go into the problem, I'll post my rig.
i7 860 (2.8ghz, NO OC)
G.Skill 8gb DDR3 1600mhz
ASUS P7P55D PRO
EVGA GTX 570 HD
Antec HX850W PSU
The GTX 570 is my newest upgrade (Yes I know my CPU might serve as a bit of a bottleneck, nevermind that) and I have no issues with it on a graphical basis. It can run Skyrim no problem and I am not seeing anything in gameplay that would indicate a problem.
However, I am getting some nasty *** coil whine. I can note it most when I first start up Skyrim (video below), and when Im in game (this is any game) there is a "buzz". From what I've determined this is either coil whine or something else entirely, however it is not a fan issue.
I have tested the GTX 570 in FurMark and there is a noticeable buzz (This is with the case panel off) I can hear each time the stress test "pulses"- however we tested the same card with the same software in a different system and heard nothing. I do not suspect this is a faulty card.
The only other things I can think off is either the mobo, or the PSU. The mobo I got in December 2009, while the PSU I got in early September 2011. Given by age I'd say it's the mobo but I have no definitive way of telling. Unfortunately I dont have either a spare mobo lying around, and my old PSU is not capable of running the 570.
Is there anything I could be overlooking, or any stress software I can run? I should also note we did a CPU stress test, that yielded no results either.
Anyone's help in this is greatly appreciated
VIDEO:
Listen with headphones if you can.
ASUS P7P55D PRO
EVGA GTX 570 HD
Antec HX850W PSU
VIDEO:
