- Oct 4, 2001
- Milton Keynes, U.K.
- Thread Starter
- #101
Lemme Know how it goes,
Good Luck,
M_N
Good Luck,
M_N
Maximus Nickus said:Great! Well-Done!
No the overclocker he doesn't require more fans, he doesn't have the room nor does he want the noise.
Most PC's have a higher case temp with the side on, unless you have an insane amount of noise and fans.
Great job gulp35!
M_N
the overclocker said:
un nope, if you have good fan setup, forced cooling is better, otherwise we would not have fans on heatsinks, see here: http://www.overclockers.com/tips824/
the main reason for not stacking fans close together is becaus ethe air comes of the first fan at an angle of 45 degrees (or around depending on the fins) and cannot be 'caught' by the second fan, however there are excptions, if the fans spon is oposite directions but still blew the same way it works well, or possably you could use the delta fans that 'straighten' the air?
GoingH2o said:Hi Maximus,
I am planning a water-cooled setup and indeed your thread helped me a lot to decide what i need and how everything should be set up
One question tough, 2 120mm panaflo fans will be enuff i guess for a heatercore 8inchesx8inches.
Now shall i put them one in front of each other with the or one on top and the other on bottom?
Maze3
http://becooling.safeshopper.com/20/115.htm?128 (Via Aqua 1300)
or shall i go for an eheim 1250
Now for the fittings 1/2 or 3/8, if i go for 1/2 fittings on the heatercore do i have to go for 1/2 fittings also with the waterblock?
aldmjr said:Hey Maximus Nickus,
Do you have any information about the Forge Heat Sink? i need to get more info about that heat sink. your help will be highly appreciated!
Regards.
