- Feb 18, 2002
- San Antonio, TX
FINALLY!!!
hey all, i got my H2O this past thursday and spent thursday night, friday night, and all day saturday, testing soldering, cutting fitting, adjusting, cleaning, re-adjusting and so on. well my puter is back together again, WITH the sides on, since before all i had was the stock HSF on the processor, and the P/S fans with ONE EXHAUST fan to move air. Well, my reactions are kinda mixed... I've got an 80 mm blowhole on top, 60 mm exhaust on back, and the P/S fans pulling air out of the case and a pair of enermax 120 mm fans push/pulling air through a black ice extreme radiator. The intake is a hole the size of a CD on the front bottom of my case, with fiberglass air filtering material on it. It's got practically NO restriction and keeps the cat hairs away from my precious pc innards. water flows from the pump (eheim 1250) to the radiator to the block (maze3) and back again. 1/2" fittings on everything.
all connected with 3/8" ID tygon tubing that does NOT slide over 1/2" fittings without some serious finesse and some hot water to heat it up. anyways, my temps went from 68 fully loaded to 48 fully loaded. i thought that my temps would be lower. (when i touch the block itself, it's never more than a little warmer than ambient. there's a total of about 14 oz water and water wetter running through my system, should i be worried? it's pretty warm in this room too though... If anyone has any comments, or some advice pls bring it on, and thank you M_N for this thread. I wouldn't have been able to piece my setup together without it!
allen
allen
