- Nov 7, 2004
I'm putting together a cheap AMD Athlon build for a friend workplace she works now everything is used I bought the motherboard of eBay with the CPU and 256mb DDR PC2100 memory.
I'm just testing the system to make sure everything is working I found a 5GB Quantum Fireball HDD and used that so I could just get XP Pro installed.
The system:
Gigabyte GA-7DXE Motherboard
AMD Duron 1.1ghz CPU (this is what the guy said was up for auction and does show as 1150 in BIOS).
Crucial 256mb DDR PC2100
Geforce 4 MX440 64mb G.Card AGP
Creative DVD-ROM (very very old drive testing only)
and HDD above (only got testing)
Now it installs all files for stage 1 the blue screen with yellow bar when it get to stage 2 and upto the part where it's installing devices I get the following BSOD. The BIOS setting are the whatever the guy changed them at I can't quite work out what device is causing the error there's also a small message in the boot screen POST says Check System Health!
Any help would be appricated.
PS: I had to break it down to the main parts of the BSOD because I took it with my camera phone and the file size was too big.
The system:
