- Dec 15, 2010
Hi there! Have a question about my new Hardware I'll buy , maybe you can help me...
Asus M5A99FX Pro R2.0 ( people say is better than GByte...FXUD3 )
AMD FX Series FX-6300
I've yet:
Kingstone HiperX 1333 Mhz CL9 2 x 2GB
Gigabyte HD 5770 <---
Corsair H70 water cooling
Corsair 500W 80 Plus Bronze
HDD 500GB x 2 RAID 0
In the future I will replace that 1333 DRAM or try Overclock them.
Can AMD FX 6300 work with 2133 DRAM ? ( OC )
Is better Overclock DRAM 1866 CL9 to 2133 or Downclock 2133 CL11 to 1866 if my mobo doesn't support that frequency ( Dual Channel )
The price is basicly the same for 1866 and 2133.
And the other question is about make Crossfire with second 5770 GPU ( 40€ ) : - ) is good option or better forget it ?
Thank you very much
I've yet:
Thank you very much
