- Jun 1, 2012
- Clearwater,FL
I think I might be up to ~200$ in just high flow fittings at this point.
The channel thickness is what i mean.
Thanks,KΓλ©KΣΓ™;7213615 said:Very cool stuff.
Nice I'm jealous. Did they have all those sizes that I was able to piece together?NEVA!!!! i have an equivalent set made by snap-on. cant read the brand on yours
Also, how would I like, verify whether or not I need to reseat the cpu cooler?Ohh yea, moving a PC can change things. What air heatsink you using?
That case on the carpet even with the legs can reduce the area open to good airflow. Even a peice of cardboard would help if you use that area as active intake.
Well, you mention a V8. Pretty heavy. Never sure of the jiggle it got. What were temps before?
Yea, I guess common sense would dictate that. I'm just lazy at the moment because I'd rather spend the time putting the finishing touches on the cooling loop I'm building.If you got paste and the time, I'd do it.
Unfortunately they are, maybe in a few months, say around November, the markets will pick up and companies will start hiring againGreat luck on the intership, they are hard to come by these days.
this is pretty cool! so much DYI stuff!
you using copper as the heat transferral material there?
probably best choice, as the one things that I know which has higher thermal conductivity are both pretty expensive. (silver and diamond) ... hahahahah, it will be soooo funny if someone has a Diamond THAT big, and decided that it is best to be made into a Heatsink. hahaha.
No the block didn't leak at all, however, the brass fitting got improperly deformed upon torquing the outer nut on one side and was dripping.(Removed quoted post and response. -hokie)
@ merz
It's looking very nice, glad to see you got time give it a run. Did your block leak at all?
