Hi all, I recently unintentionally got involved in a bit of watercooling and am about to buy the rest of the components for my first custom loop. Funny story; bought a H60 on the cheap, found that it didn't perform any much better than my D14. Came across an Alphacool XT45 560 that was so cheap it was too good to pass up so I bought that intending to mod it onto the H60. However the advice at the end of the prospect was to forget it altogether as there would be problems with pump strength and air in the loop. So here we are. Rad is about 200% too large for a C70 so we'll need to drill holes for the pipe out back and get some long *** bolts to sit on top.
I did alot of research especially into port/fitting sizes including an embarrassingly late realization that comp and barb fittings don't refer to the same thing.
It hits you very slowly how expensive WC can get but it's been awhile since I did something fun for my computer and we already have a giant rad so why not. Didn't skimp on the pump as it seems all the cheap ones on Amazon have bad reviews, not even taking a chance on those that don't have any. Other things like that slightly ghetto reservoir and plebeian barb fittings (will get clamps from hardware store) don't matter that much though I hope? Here's a shortlist of parts that'll hopefully make up a basic loop for a badly binned and pending-delid 3770K. Have I gotten it right, do they fit together?
Alphacool XT45 560
Swiftech MCP50X
LENX Raystorm
Phobya double 5.25" res
1/2" ID 3/4" OD tubing
Alphacool XT45 560
Swiftech MCP50X
LENX Raystorm
