ICS is so much better then any others, they really fixed alot
I second GoD's way of thinking.
I like Apple's airtight philosophy to some extent. You download something from the App Store, it works, no need to check for virus or anything. Apple says an update is coming, it's coming. You connect your iOS Device to your Mac with a properly crafted iTunes library and everything flows without you messing with folders. You buy a certified accessory, you plug it, it works. Easy.
But, I also like Android for the lack of this airtight philosophy. You want to root your phone? Fine. Easy. You want to use another ROM or craft one yourself? You can do it! You want to tweak your Android system? Got that covered! Or maybe trim it to the bone? Yup, you can. What about creating accesories for it? ADK has you covered!
It's like comparing Apples to oranges a little bit, IMHO.
What does "getting your work done" have to do with anything?
but this thing just works. And easily.
I love it when Apple users say that.
My Android device "just works", too. Very easily.
My android devices work as well. I do find however that my Apple stuff works more simply. I don't have to click twice or even three times to do things. It's a much simple interface IMHO. Another thing I've noticed is when I scroll a screen on my Android stuff, the words are blurry for a split second until it completely stops. Not a huge thing, but it's odd. I personally just find IOS easier to use, easier to teach someone how to use, and has less steps involved in most tasks.
I have both as I am not indebted to any company. I like to have/use both so I have an understanding of both. There are things I like about Android based phones over Apple phones, but to each his own.
Android 4.2 is awesome.
Hard to get a good feel for android... Very dependent upon how the manufacturer packages the OS up on your device.
Been almost a week now on my Nexus 4... And it is great.
Unadulterated android is good. Next best thing is cyanogenmod, but that's dependent upon how well your device is supported. After that are all the branded packaging of android with their own bloatware and other crap.
