JTanczos said:I sadly destroyed mine when I was testing it out on sunday night. Zip tie fell in the blades and it broke 3 off before throwing it out of the way. I started to cry almost immediately yelling out several 4 letter obsenenities! It was heart breaking! My voice was shakey the next 4 hours and I couldnt sleep! Did I take it way too seriously? Maybe, but that fan was cool as hell! They were clean breaks so maybe if I find incredibly strong plastic glue I will try to rebuild it.
I couldnt afford the first one so I probably wont buy one for $20 more.
More luck to the rest of ya!
JT
You're in luck! I've been able to repair broken fan blades before! Go out and buy some 2 part epoxie and use that to glue them back together. Use it very sparingly (you don't want to use too much or else you will throw the fan off balance, which will cause vibration and the bearings will wear out faster) and you have to find a way to hold the blade in the correct position until the bond hardens (I used the quicksetting type so it only took 5 minutes or so.)
