Well, I have a simple idea that could probably be done by someone with machine equipment, or at least at a local machine shop.
This was my thought process: don't try to re-invent the wheel but improve on what is currently available. So I thought "what is the best HS that is simple enough for someone to make?" It had to be 1 material only (no Cu/Al hybrids.) Well, the answer is obvious: the Millenium Glaciator.
How does it get such good performance, especially for being 60mm only? It is milled from one copper piece, so no joints to hinder heat transfer, and this is also do-able at a machine shop. It has good thermal mass, meaning that while it is not a "thin-fin" design, it has lots of mass to absorb heat, with a balanced amount of surface area to expel it.
My design for: socket A, using motherboard mounting holes b/c of its massive weight. I will describe it verbally then try to get some pics up.
The base would cover the entire AMD "no-mount zone" with cut-outs if necessary for the more popular boards that don't conform. Mounting method would be the same as the Alpha8045 or the SwiftyMCX462.
Rising from the base would be fins of equal spacing and size to the Glaciator. The fins would run across the socket (same direction as socket mounting tabs.) The base area between the fins would be cut in toward the center but not farther than the mounting holes. The center would be as a solid column rising up directly above the die to the bottom of the fan, since this area has less airflow anyway might as well have more mass.
After rising up to the AMD recommended minimum clearance height (adjusted for popular mobo's), the fins would go square out to form a 92mm square. Yes, it will have a 90 or 92 mm fan, big CFM, low noise.
The fins parallel to the socket lugs would be easy to do this with; to make the top 92x92mm, perpendicular fins would have to be milled (or soldered on if necessary) to the side-most fins on the sides where the mounting screws are. The fan would mount to brackets attached to the outermost fins.
It would weigh a ton I am sure, but oh well. This is just a "more is better" heatsink, but I believe it would be effective. I know it is hard to describe verbally, but I think I made sense (mostly
)What do you think?
