If you were trying to get air to cener of heatsink. take another fanJigPu said:
Here's another theory to throw out there...
To maximize surface area, make the fins rough instead of perfectly flat.
As long as we are attaching the fins to a base (not extruding the fins out of the base), you should be able to take some rough sand paper to it to get it nice and bumpy.
Also, is there any way of forcing the heat from the center of the heat sink (where the die is) out to the edges of the heat sink? I was wondering because there is very little air coming from the center of the fan, and most of it is around the outside. So, if we could force the heat out to the edges somehow, it would be much more efficient at getting rid of the heat because the area where the most air flow is would have the most heat from the CPU.
Of course, another solution would be to find a diffrent way to mount the fan so that it blows air over the die directly rather than on the edges of the sink.
JigPu
JigPu
Trieber said:Ok, I read the first page or so, how about this idea:
Have a cube shaped heat sink, have holes drilled through it, then put an input fan on one side that has a freshair duct feeding it, and then an output fan with a duct to get the air off, then to top it off, a fan on top, preferably low CFM and low RPM to cool the die area directly, somewhat like this websites HSF called "The Core"
http://www.overclockershideout.com/...tore_Code=o&Product_Code=CHS&Category_Code=HS
Tell me what you think of my idea above, and about that HSF.
