QuietIce
Disabled
- May 7, 2006
- Anywhere but there
The CPU must have given up - MemTest doesn't stress the CPU a whole lot.
What was the vCore ...?
Stayed at it's default setting at 1.35v, then I bumped it up to 1.4v to no avail. What has made me stumped is, it was possible before to do a blend test with this configuration.The CPU must have given up - MemTest doesn't stress the CPU a whole lot.
I've already considered doing processor overclocking first over memory after discovering that the processor speed affects the whole overclock. But with my new cooler arrival stalled, it'll probably have to wait till then. One of the main things why I love overclocking is actually like a test of luck. It's exciting to know if your processor is either a lump of gold, or a dud. Either way, I still live with itI've come to dislike P95 blend. I either use large or small FFT's now since I've had several CPU's crap out under blend then run SETI forever without a bad work unit. In the past SETI would sometimes crash a system that was P95 blend stable so I wonder if they've changed the P95 program?
Anyway, you've found the board top end so the next step, IMO, is the CPU OC. I know infinitevalence shows RAM next in his OC thread but to me that's backward. Since CPU speed is by far the most important aspect of an OC I always do it first then RAM test such that I don't ruin the CPU over-clock. I also try to keep RAM speeds near their stock rating while OC testing the CPU - and that's even different than my AM2 OC sticky (I really need to edit that one of these days!) ...
I was able to get an Arctic Cooling Freezer 64 Pro for an affordable price, it'll definitely work better than an XP-90 or the stock four heatpipe AMD cooler.Just a final note, then.
As long as you stick to stock vCore your temps won't go up much, so push the CPU all you can at stock volts and let it run that way while you await the new cooler. Generally 55°C at full load is acceptable, 60°C max for 24/7 computing ...
Don't have to be sorry man, I would have been pointlessly wasting a lot of time if not for your adviceSorry to hear about the problems. Must be a DFI thing, I didn't have those kind of issues with my NF4 builds ...
Well, my processor was a random one so I guess I should be happy with what I've got, rather than complaining about something that I can't or don't have.Processor stepping makes a big difference with the Toledo's. I've got a couple of late run Opty 165's running almost 3.0 GHz on air but my Opty 180 hit a wall at 2.8 GHz on water. It's all a matter of the stepping since AMD was binning them pretty tight for awhile and playing with the silicon a lot.
A fluctuating rail at those voltages could just mean you're close to burnout on the motherboard MOSFETs. The whole system starts to demand more and more as the voltage goes up - mostly due to greater resistances at higher temps. That same rule applies to the voltage converters and regulators as well as the CPU. How hot are the motherboard chips - have you checked them (fingertip "probe" ) at those voltages?
My personal limit for s939 K8's is 1.55v. I run a couple of my rigs at that vCore for about a month/year during the SETI races. Usually, though, they're turned down to 1.45± vCore just to keep room temps down. I've seen people run 1.6v semi-long term with reasonable temps - like OC'ing it's a matter of personal taste (and risk) ...
I actually set a goal to reach at least 2.6GHz, but a 100MHz short from my target might not be so bad.2.5 GHz is not bad for a 3800!
If it's just a random chip then you could have easily gotten one of the mid-run CPU's and, if so, that's a very good OC ...
