- Oct 22, 2003
- Dallas, Texas
Even if not true, it was a fun read
If all you're doing is screwing up the partition table, how in the world would that void your warntee? My warntee isn't voided by partitioning weird portions of my drive, and this I'd say is a VERY weird portion (since it's the same portion ). The warntee is also not voided by screwing up the partition tables manually. However, neither are covered reasons for returning the drive if you can't fix it yourselfDissolved said:I would NOT try this on a drive that is new. Doing this will void your warranty, and could kill the drive. and YES maxtor/wd can see what you done, and im sure they wouldnt rma your drive if they knew.
NoteUser said:I just realized that Partiton Magic 8 Pro isn't 100%
It tells me 228 but the C: properties says 223.
What gives Ohwell, still in the 90%
ToiletDuck said:I got 155bg out of a Seagate 111.7 GB drive. And around 113GB out of 60GB. No time for test yet. I'm resetting up my system to try it out. I'll make a full review of the process I used to do this when I return.
Duck
ToiletDuck said:Are you telling me all 3 of them are corrupt past the 111.7GB area?
A representative for large hard drive distributor Bell Micro said: "This is NOT undocumented and we have done this in the past to load an image of the original installation of the software. When the client corrupted the o/s we had a boot floppy thatopened the unseen partition and copied it to the active or seen partition. It is a not a new feature or discovery. We use it ourselves without any qualms".
operating system is telling you that your drive is bigger than that because it's using a false partition table
ToiletDuck said:I've also heard rumors that random information is stored there and that is how FBI investigators find out what you have been doing even if you do erase your harddrive.
