- Mar 7, 2004
- Phoenix, since 03/2014
For those with Abit boards, couldn't Tic Tac just tweak the BIOS to add the support for Mobile Bartons? He's seemed to have done all sorts of other crazy things with the BIOS.
There will not be a difference.Prevail said:so why hasnt someone done a realworld bench against the mobile barton and standard barton at identical clock multi mem settings?
65stang said he has both and im sure many others here do also. i believe pcmark would be the ideal testbed seeing as windows media encoding is very reliant on cpu optimization. id be very interested in these results.
johan851 said:I doubt it does either. Does a laptop suffer from not having performance optimizations? As long as WinXP (or whatever OS) realizes that it's got an AMD CPU and loads the correct drivers and such for it, there should be no difference whatsoever.
Psykoikonov said:IBTW the reason load times on WinXP is differenet from one reboot to the next with same components, install new app or not is....restore point creation...new settings to be loaded for first time...changed settings etc. etc. etc.
