well, after quite a while with two dual xp systems, I'll drop my final thoughts/comments.
The tyan (and it's replacement rma board) was sent back to newegg. The first tyan I have 100% confirmation that it didnt work properly, but the second board I believe may have been the victim of a faulty reset switch.
The first tyan board, I checked every component, including disconnecting all the case wires, and also removing it and running it w/o a case. It wouldn't boot for anything.
The second Tyan board I got (the RMA) also would not boot, but I didn't do a super extensive like I did with the first Tyan board. I dont THINK that I disconnected all the case wires (namely the reset). I did check all the major components again, as well as another PSU (again). In my haste, I assumed the second board had the same problem... so I purchased another Asus board for work.
The asus board came in, and guess what... no boot. after trying the same thing as I went thru with the tyans, I found that the reset button was stuck on. This caused the fans/drives to start up, but not the board. Now, I assume that the second tyan probably had the same proble, altho I can only speculate. However, i'm positive that wasn't the first tyan's problem.
That having been said... The first Tyan setup, while it was working for me, performed flawlessly. Both Asus setups have also performed without a hitch as well. The home asus did have an evian.sys BSOD after I exited an old version of sandra (tracked down to a promise raid controller file), and also when I oc'ed the home cpu's up to 150FSB, when I would exit the folding client, I would get a "kernel mode trap" BSOD. This was solved by moving down to 148FSB. (for some reason, the 149FSB setting in the bios actually boots to 154FSB... assume that's a bios glitch)
at 148FSB and lower, I can leave both the asus systems (have only used the work asus system at 133fsb) running 24/7 and only reboot when I install/remove software, or want to change bios settings, etc.
A note on temps...
Both computers are in full tower cases. At work, the room temp stays at an almost constant 65F (it's a TV room, has a TON of equipment that doesn't work well with heat). My home room temp stays around 72F (this fluctuates slightly). At work, I am using the default HSF from AMD... while at home I am using a watercooling setup (previously posted somewhere in this thread).
The work computer (dual 1700's) with 2x 80mm fans and one PSU fan will get to 50C and higher if both cpu's are stressed for long. If left to idle overnite, they sit closer to high 30c/low 40C.
At home, not overclocked (dual 1800's) and with the 120mm radiator fan turned down to nearly silent, cpu's top out temp wise at around 38C. When I overclock to 1701mhz (148fsb), I turn the radiator fan back up to default speed, and temps top out at 40C.
In my opinion, I am uncomfortable with the work computer's temps... especially considering the chilly temp of the room to begin with. It will soon be getting another pair of 80mm fans to help circulate the case air more.
I still would rather have the Tyan's additional PCI slot, and the Tyan's onboard NIC. but that is just wishful thinking for me... but something you may want to consider before deciding on a board.
All in all, if I had it to do all over again... I would stick by my guns and go again with the tyan for a work computer (altho I'd be seriously hoping for one that WORKED for longer than a week) and the asus one for my home/play computer.
I cant say that I'd recommend dualxp cooling (especially if you plan on oc'ing) for aircoolers, unless you dont mind noise.
I think this will do it for my comparison of the two boards. I'll check this thread to answer comments/questions in the future. Or to post if I do encounter any problems with the asus setups.
All in all, it's been a fun experiment (moreso with the home one, cause I had less headaches, and more fun overclocking it). And (watercooling not included) the price definitely justified the additional $250 or so I spent over a single cpu system.
hope this has helped shed a little light...
