- Oct 16, 2006
I challenge the Idea that ALL Dyes are bad. There seems to be something going on. Either the TYPE of Dye, Temps, Algae, fluid choice, or all of the above may create the issue. I used Primo Ice with dye and had 0 issues. After 2 years I switched fluid and feared that the dye may create issues, so I switched to clear fluid. With that said, has anyone actually pin pointed the dyes in question, associations with fluid choices and dies, and other things to find out what is causing this in some machines but not in all?
Ohh BTW, I am no longer willing to try dyes in My Machine because of the stories. They got me running scarred. I wonder if I am afraid of something that is not the problem
