- Feb 10, 2006
- Folding@Home on the Blue Ball
i was goin to ask if we needed to do all that it seemed to be redundant after all flex bison stuff as i sped resd the terminal will it compiled before
Hack30 said:i was goin to ask if we needed to do all that it seemed to be redundant after all flex bison stuff as i sped resd the terminal will it compiled before
Hack30 said:do i have to get sidenet thats a 32 bit to 64 bit converter right?
Shelnutt2 said:sidenet is just a nice little script that sets up wine for us. It creates a easy to get to "c" directory. It adds a wine menu the the "applications" menu. It setups task manager..its just a nice little script.
for sidenet when installing, when it gets to the point and asked you if you want to install options 0, 1, 2 or 3. Just do 0. I had a slightly different sidenet script I linked to but I just tried the link adn it was dead..so I need to find someone that will host my slightly older but better for us sidenet script..
Hack30 said:I cant d/l it your link is to a password prtected sight
david@david-toshiba:~$ cd ~/wine-git
david@david-toshiba:~/wine-git$ wine "c:\EMIII\EMIII.exe"
Application tried to create a window, but no driver could be loaded.
The X11 driver is missing. Check your build!
wine: Unhandled page fault on read access to 0x00000e08 at address 0x6600e84b (thread 0009), starting debugger...
Unhandled exception: page fault on read access to 0x00000e08 in 32-bit code (0x6600e84b).
err:dbghelp:pe_load_dbg_file -Unable to peruse .DBG file DLL\MSVBVM60.dbg ("\x08\x01")
Register dump:
CS:0073 SS:007b DS:007b ES:007b FS:0033 GS:003b
EIP:6600e84b ESP:0033fcac EBP:0033fcc8 EFLAGS:00010202( - 00 - -RI1)
EAX:00000e08 EBX:66000000 ECX:0033fca0 EDX:006e0100
ESI:00000e08 EDI:00000001
Stack dump:
0x0033fcac: 6610e470 6600ef50 6601cb0d 66003138
0x0033fcbc: 66000000 00000001 66000000 0033fd08
0x0033fccc: 66001b25 66000000 00000001 00000001
0x0033fcdc: 00110748 00000000 0033fd08 7eff5904
0x0033fcec: 7efb42e5 66000000 00000001 00000001
0x0033fcfc: 7efb5aed 7efb53a9 7eff5904 0033fdb8
Backtrace:
=>1 0x6600e84b in msvbvm60 (+0xe84b) (0x0033fcc8)
2 0x66001b25 in msvbvm60 (+0x1b25) (0x0033fd08)
3 0x7efb564c MODULE_InitDLL+0x16c(wm=0x110748, reason=0x1, lpReserved=0x1) [/home/david/wine-git/dlls/ntdll/loader.c:842] in ntdll (0x0033fdb8)
4 0x7efb5aed process_attach+0x12d(wm=<register EDI not in topmost frame>, lpReserved=0x1) [/home/david/wine-git/dlls/ntdll/loader.c:912] in ntdll (0x0033fdf8)
5 0x7efb5a32 process_attach+0x72(wm=<register EDI not in topmost frame>, lpReserved=0x1) [/home/david/wine-git/dlls/ntdll/loader.c:904] in ntdll (0x0033fe38)
6 0x7efb86a1 LdrInitializeThunk+0x371(unknown1=0x0, unknown2=0x0, unknown3=0x0, unknown4=0x0) [/home/david/wine-git/dlls/ntdll/loader.c:2168] in ntdll (0x0033ff08)
7 0x7ee7e2ca start_process+0xba(arg=0x0) [/home/david/wine-git/dlls/kernel32/process.c:810] in kernel32 (0x0033ffe8)
8 0xb7eba607 wine_switch_to_stack+0x17() in libwine.so.1 (0x00000000)
0x6600e84b: movl 0x0(%esi),%eax
Modules:
Module Address Debug info Name (32 modules)
PE 400000-5c2000 Deferred emiii
PE 66000000-66152000 Export msvbvm60
ELF 7bf00000-7bf03000 Deferred <wine-loader>
ELF 7e939000-7e9d1000 Deferred oleaut32<elf>
\-PE 7e950000-7e9d1000 \ oleaut32
ELF 7e9d1000-7e9e4000 Deferred libresolv.so.2
ELF 7e9ee000-7ea0c000 Deferred iphlpapi<elf>
\-PE 7ea00000-7ea0c000 \ iphlpapi
ELF 7ea0c000-7ea60000 Deferred rpcrt4<elf>
\-PE 7ea20000-7ea60000 \ rpcrt4
ELF 7ea60000-7eafb000 Deferred ole32<elf>
\-PE 7ea70000-7eafb000 \ ole32
ELF 7eafb000-7eb41000 Deferred advapi32<elf>
\-PE 7eb10000-7eb41000 \ advapi32
ELF 7eb41000-7ebc5000 Deferred gdi32<elf>
\-PE 7eb50000-7ebc5000 \ gdi32
ELF 7ebc5000-7ecff000 Deferred user32<elf>
\-PE 7ebe0000-7ecff000 \ user32
ELF 7ee0d000-7ef2b000 Dwarf kernel32<elf>
\-PE 7ee30000-7ef2b000 \ kernel32
ELF 7ef2b000-7ef36000 Deferred libnss_files.so.2
ELF 7ef36000-7ef40000 Deferred libnss_nis.so.2
ELF 7ef40000-7ef56000 Deferred libnsl.so.1
ELF 7ef56000-7ef7c000 Deferred libm.so.6
ELF 7ef7c000-7f000000 Dwarf ntdll<elf>
\-PE 7ef90000-7f000000 \ ntdll
ELF b7d53000-b7d5c000 Deferred libnss_compat.so.2
ELF b7d5d000-b7d61000 Deferred libdl.so.2
ELF b7d61000-b7e95000 Deferred libc.so.6
ELF b7e96000-b7ea9000 Deferred libpthread.so.0
ELF b7eb3000-b7fc4000 Dwarf libwine.so.1
ELF b7fc6000-b7fe1000 Deferred ld-linux.so.2
Threads:
process tid prio (all id:s are in hex)
00000008 (D) C:\EMIII\EMIII.exe
00000009 0 <==
Hack30 said:would that have anything to do with this
Code:blah blah my bad
you mean step 15 right?? i thought we could skip 4-14.??
Hack30 said:all right i had to keep going with it
image too large
now we have to work on getting it to run correctly
after all this what else will work basically out of the box now?anything for windows??or will i still have to tweek it?
sweet when will that be out, i like easy, hard is good too it forces me to learn.
image to large? What? I didn't get that error on my laptop.
Hack30 said:screen shot image to large i cant show you it is up.
max size 158 megs? file is 346megs. cant post it.
havent found where i can resize it yet in linux.
tpf is off progress bar is off wu time to complete is off wont get stats but it does show what protien its crunchin.![]()
sean uk said:maybe a silly question as i'm quite new to linux
but why don't you just
[root@localhost ~]# yum install wine
[root@localhost ~]# yum install wine-tools
this will load wine and all needed depents
and if you set up yum to include the livna repositories you can install nearly any program or driver just by yum install *********
by using this method i had firefox, xine, wine ,internet explorer ,autocad and skype set up and working in an hour and was only a couple of days into using linux
Shelnutt2 said:Thanks to landshark, for hosting the file, you can now just download a .deb file for anyone running a debian based distro!
jws2346 said:Man, you and LS (aka Gary) are freaking fantastic. Now for a real "noobie doo" question, where do I go to download the .deb file?(try not to pass out laughing, but I'm serious)
Patched said:psst jws2346, the first post has been edited with what you might be looking for![]()
