- Jan 24, 2006
- Colorado
I'm working on 2 computers currently, and both are experiencing some problems. They are both clear of Malware, Virii and Rootkits. I've run SFCs on both, as well as CHKDSKs.
Computer #1 is an All in One Gateway computer that I'm getting error code 6008 in Windows 7. I can't seem to determine the root cause to this issue. The owner of said computer mentions that the computer is shutting completely down. (It's not a BSOD reboot like I would normally think, just a full shutdown). I've done some research, and 6008 just seems to be a marker of the improper shutdown. There are no other critical errors other than this. Any input on what could be an issue here?
Computer #2 is running Windows Vista, and I'm told by the owner that it's BSODing all the time. I checked the event log and error 41 pops up, which shows a bugcheck, but the bugcheck value is 0 for all hex information. So I cannot find the information required from the system. Any thoughts on this?
Specs and more info can be given if needed. Thanks.
