I just got this GPU about 3 to 4 days ago. Everything seems to be running fine. I just want to know whats the best overclock settings for this card?
I know the best way to start off overclocking is to move the core clock and the memory clock every 10 to 15+mhz and see whats stable till you hit some artifacts. But to be on the safe side what setting should i be at overall for this card? :
Here is a link that suggest a good overclock settings for this card, but doesn't give any info on my what my voltage should be? :http://www.bit-tech.net/hardware/graphics/2015/05/08/evga-geforce-gtx-970-ssc-acx-2-0-review/9
I know i have to increase the voltage a bit if you going to overclock the core clock for this card over 1400mhz at least.
MY CPU IS FX 8350 which is overclocked to 4.4ghz with 1.45volts, i put the voltage setting for my north bridge on auto
RAM: 8GB WITH 1866mhz
and 250gb samsung ssd 840.
