- Dec 23, 2003
- California
i got my mobo down to 17C and my cpu down to 35C, so i got some pretty good temps. mobo normally is like 35C and CPU is normally 55's. and i dont know why my computer runs so hot. and i never even overclocked it yet! well it maybe because i have no case fans, and i only have cpu fan and psu fan. most of the time i leave my side panel off and put a nice big fan next to it. so i can mantain a decent cpu and mobo temp. the fan that i put on the side panel is the equalivint of a 200 CFM fan. so it is a nice fan to put on my side panel when i am gaming on this crapper.
can someone please tell me why my computer runs so hot? oh yeah those temps are at idle too! So there is definatley a problem.
i think it says somewhere on there that i have a socket 478, but i really have a socket 423.
oh yea here are my pc specs at idle (typing this thread)
SiSoftware Sandra
System
Manufacturer : Compaq
Version : C01BDABB
System Chassis
Type : Desktop
Can be locked : No
Boot-up State : Safe
Power State : Safe
Thermal State : Safe
Mainboard
MP Support : 1 CPU(s)
MPS Version : 1.40
Model : 077Ch
System Memory Controller
Error Correction Capability : None
Number of Memory Slots : 3
Maximum Installable Memory : 3GB
Bank 1 - XMM1 : JEDEC ID:2C FF FF FF FF FF FF FF 16LSDT3264AG-133E1 AD912057 DIMM Synchronous SDRAM 256MB/64 @ 133Mt/s
Bank 2 - XMM2 : JEDEC ID:2C FF FF FF FF FF FF FF 8LSDT1664AG-133E1 8BCF0945 DIMM Synchronous SDRAM 128MB/64 @ 133Mt/s
Bank 3 - XMM3 : Empty
FLASH Memory Controller
Number of Memory Slots : 1
Bank 4 - XU15 : Chip Non-Volatile FLASH 512kB/4
Chipset 1
Model : Intel Corporation 82845 Brookdale Host-Hub Interface Bridge (A3-step)
Bus(es) : X-Bus AGP PCI IMB USB FireWire/1394 i2c/SMBus
Front Side Bus Speed : 4x 100MHz (400MHz data rate)
Maximum FSB Speed / Max Memory Speed : 4x 100MHz / 1x 133MHz
Width : 64-bit
IO Queue Depth : 12 request(s)
Chipset 1 Hub Interface
Type : Hub-Interface
Version : 1.00
Number of Ports : 1
Width : 8-bit
Full Duplex : Yes
Multiplier : 1/1x
Speed : 4x 66MHz (264MHz data rate)
Logical/Chipset 1 Memory Banks
Bank 0 : 128MB SDRAM 3-3-3-6CL
Bank 1 : 128MB SDRAM 3-3-3-6CL
Bank 2 : 128MB SDRAM 3-3-3-6CL
Speed : 1x 133MHz (133MHz data rate)
Multiplier : 4/3x
Width : 64-bit
Refresh Rate : 15.60µs
Power Save Mode : No
Fixed Hole Present : No
APIC 1
Version : 2.00
Speed : 16MHz
Multiplier : 1/2x
Maximum Interrupts : 24
IRQ Handler Engaged : Yes
Enhanced Support : No
Memory Module(s)
Memory Module 1 : Micron 16LSDT3264AG-133E1 572091AD 256MB 16x(16Mx8) SDRAM PC133U-333-542 (CL3 up to 133MHz) (CL2 up to 100MHz)
Memory Module 2 : Micron 8LSDT1664AG-133E1 4509CF8B 128MB 8x(16Mx8) SDRAM PC133U-333-542 (CL3 up to 133MHz) (CL2 up to 100MHz)
Environment Monitor 1
Model : AD ADM1028 SMB
Version : 0.02
Mainboard Specific Support : No[/COLOR]
Temperature Sensor(s)
Board Temperature : 39.0°C / 102.2°F td
CPU Temperature : 62.0°C / 143.6°F td
AGP Bus(es) on Hub 1
Version : 2.00
Multiplier : 1/2x
Fast-Writes Enabled : Yes
Side Band Enabled : Yes
Aperture Size : 64MB
PCI Bus(es) on Hub 1
Version : 2.20
Number of Bridges : 2
PCI Bus 0 : PCI (33MHz)
PCI Bus 2 : PCI (33MHz)
Multiplier : 1/3x
LPC Hub Controller 1
Model : Intel Corporation 82801BA (ICH2) LPC Interface Controller
ACPI Power Management Enabled : Yes
Random Number Generator Enabled : No
Random Number Generator Support : Yes
Delayed Transaction Enabled : Yes
LPC Legacy Controller 1
Type : SMSC LPC v1
Version : 6D.00
Number of Enabled Devices : 5
USB Controller 1
Model : Compaq Computer Corp (Now owned by Hewlett-Packard) 82801BA/BAM (ICH2/ICH2-M) USB Universal Host Controller
Version : 1.10
Interface : UHCI
Channels : 2
Speed : 48MHz
Supported Speed(s) : Low (1.5Mbps) Full (12Mbps)
Legacy Emulation Enabled : No
USB Controller 2
Version : 1.10
Interface : UHCI
Channels : 2
Speed : 48MHz
FireWire/1394 Controller 1
Model : Accton Technology Corp TSB12LV26 OHCI Compliant FireWire Controller
Version : 1.00
Interface : OHCI
Enhanced Support : Yes
Channels : 64
Speed : 400MHz
System SMBus Controller 1
Model : Intel 801xx SMBus
Version : 1.02
Slave Device Enabled : Yes
Speed : 16kHz
Expansion Slot(s)
AGP Slot J40 : AGP-4x 32-bit +3.3V Half-Length Used
PCI Slot 1: J20 (1h) : PCI 32-bit +5V PME i2c/SMBus Half-Length Used (Intel Corporation 82845 Brookdale Host-AGP Bridge (A3-step))
PCI Slot 2: J21 (2h) : PCI 32-bit +5V PME i2c/SMBus Half-Length Used
PCI Slot 3: J22 (3h) : PCI 32-bit +5V PME i2c/SMBus Half-Length Available
Port Connector
COM A - COM A : Serial Port 16550A - 9 Pin Dual Inline / DB-9 pin male
COM B - COM B : Serial Port 16550A - 9 Pin Dual Inline / DB-9 pin male
PAR - PAR : Parallel Port ECP/EPP - 25 Pin Dual Inline / DB-25 pin female
USB 1 - USB 1 : USB - USB / USB
USB 2 - USB 2 : USB - USB / USB
KBD - KBD : Keyboard - PS/2 / PS/2
MOUSE - MOUSE : Mouse - PS/2 / PS/2
CD-AUDIO IN 1 : Audio - CD-ROM Sound Input / None
TV & DVD Audio In : Audio - CD-ROM Sound Input / None
P20rimary IDE : None - ATA / None
P21:Secondary IDE : None - ATA / None
P10:Floppy : None - Floppy Disk / None
J13 - Line I/O: MIC : MIDI - None / Mini-DIN
J15 - Line I/O: Line In : MIDI - None / Mini-DIN
J13 - HeadPhone & Line Out : MIDI - None / Mini-DIN
P9: NIC : None - None / None
Chassis Fan : None - None / None
P6: Speaker : None - None / None
Performance Tips
Notice 224 : SMBIOS/DMI information may be inaccurate.
Tip 2511 : Some memory slots are free so the memory can be easily upgraded.
Warning 2507 : Mainboard has too few memory slots. Upgrading the memory may be difficult or expensive.
Warning 2508 : All memory slots are full. Upgrading the memory may be difficult or expensive.
Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.[/color]
SiSoftware Sandra
System
Version : C01BDABB
System Chassis
Type : Desktop
Can be locked : No
Power State : Safe
Mainboard
MPS Version : 1.40
Model : 077Ch
Chipset 1
Width : 64-bit
Version : 1.00
Number of Ports : 1
Width : 8-bit
Full Duplex : Yes
Multiplier : 1/1x
Multiplier : 4/3x
Width : 64-bit
APIC 1
Version : 2.00
Speed : 16MHz
Multiplier : 1/2x
Memory Module(s)
Version : 0.02
Version : 2.00
Multiplier : 1/2x
Version : 2.20
Multiplier : 1/3x
Type : SMSC LPC v1
Version : 6D.00
USB Controller 1
Version : 1.10
Interface : UHCI
Channels : 2
Speed : 48MHz
USB Controller 2
Version : 1.10
Interface : UHCI
Channels : 2
Speed : 48MHz
Version : 1.00
Interface : OHCI
Channels : 64
Speed : 400MHz
Version : 1.02
Speed : 16kHz
Expansion Slot(s)
Port Connector
Performance Tips
