- Nov 10, 2002
- Stuttgart, Germany
Over the last months i've been working on a little fanbus project:
- 8 temperature sensors
- 8 pwm outputs (2x10A, 6x 4A)
- automatic fan speed control based on temperature
- graphic 128x64 display
- microcontroller-controlled (Atmel AVR) / programmed in asm and c
- rs232 interface to pc app.. will look into using usb soon
- settings are stored in non-volatile eeprom and restored at bootup
The LCD. Sorry for the red reflection of my intellimouse explorer
Only temperature for CPU and GPU is correct right now as i haven't attached the other sensors.
The little triangle below the load bar is the average cpu load over the last 3 minutes..
The app you use to change settings / view data. Fanbus works without it but has no cpu/network data when the app is not running.
At the moment i'm looking into adding cpu overtemperature alert+shutdown.. any suggestions on how to do it in hardware?
cut-off the green power wire?
Any suggestions for controls? buttons? jog wheel? be creative..
Comments? Questions? Suggestions
