First of all, Hi!
Please be soft on me, this is my first ever WC build.
So lets start.
I am about to build my first WC and humbly asking experienced ones for your opinion, thoughts, comments and advice.
Goal:
- quiet. quiet as much as possible. preferably do not want to hear it.
- efficient. efficient so i to not need to worry about my hardware.
- redundant. if i am away and **** hit the fan, i want to make sure my HW is ok.
- no WOW and BLING factors neccessary in build. I care about what equipement can do and not how it's look like (to degree). So no glowing in dark **** or making cookies.
Usage:
- gaming. I do like playing games. A lot and as much as i can.
- home theater
- quite a lot of 3D modeling such as 3DS etc. when I am not playing games
Hardware:
- 2x ASUS HD7970-3GD5. Also I am planning to overlock it up to 1100MHz link
- 3x 24" 60Hz screens in portrait mode, native res: 3600x1920
- I am not mentioning CPU, RAM, MOBO, HDD etc. since some of those already does have separate WC or do not require it really. For instance CPU does have Corsair H50 link. I will wait until good moment and include those in the loop eventually.
- HAF X Enclousure to fit it all
After reading quite a lot on WC I came up woth this list of equipement to purchase. Money are not an issue really but lets do not go crazy :
0.
1x EK Water Blocks EK-Supreme HF Full Copper universal Easy
1.
2x WC Block EK-FC7970 link
2.
2x Backplate link
3.
2x I/O Bracket link
4.
2x Koolance Dual VID connection nipple variable G1/4" - 2-3 Slots - Black link
5.
1x WaterTank link
Problem with water tank is, I was not able to figure out pumps I do need. It says D5 and I thoughts about two Liang D5 Vario, but not sure will it fit. So instead that I went for kit with two pumps included. Please comment on this since I have no clue is it good ones :/ link
6.
1x 180deg variable connector link
Since I am planning to run pumps in serial I need to connect two pumps together. How safe are those 180deg connectors are? will it leak?
7.
1x Radiator MO-RA3 9x140 Pro Black link
This one seems to be quiet and this is what I am after. Also I thought it will reduce chance of damage by sitting next to the enclose and not above it, if it will starts leaking.
8.
2x Rad Grill Watercool MO-RA3 420 link
9.
2x Koolance screw plug G1/4" knurled link
Not sure is those were added to water block so just in case if they were not, want to have them
10.
2x Alphacool 16/10 compression fitting 90° revolvable G1/4
Also good to have couple of those if have need of sudden turn or lack of space while laying tubes
11.
10x Alphacool 16/10 compression fitting G1/4 - shiny copper
12.
1x Koolance 4-way outlet valve link
Just in case I suddenly feel to stop water flow Want to mount it somewhere ease accessible lets say in case of hell break loose and loop start leaking I'll use this emergency stop valve.
13.
1x Koolance quick release connector 16/10mm (ID 3/8" OD 5/8") plug (High Flow) - VL3N
14.
1x Koolance quick release connector 16/10mm (ID 3/8" OD 5/8") coupling (High Flow) - VL3N
15.
Masterkleer Slang PVC 16/10mm (3/8"ID) Clear 15m (50ft) "Boxed"
16.
1x link
Just in case of :]
I hope I did not missed anything. Did had some difficulties with finding right sizes to all components. As you already notice everything is running on G1/4". Also I stayed away from mixing aluminum in the loop so everything is in brass, copper or other non corrodible materials. As coolant I am planning to use distilled water from local HW store. I do not want to use any premixed coolant solutions or some glowing UV coca-cola.
Let's start.
So lets start.
Goal:
Usage:
- home theater
Hardware:
0.
1.
2.
2x Backplate link
3.
2x I/O Bracket link
4.
5.
1x WaterTank link
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
1x link
Just in case of :]
Let's start.
