Hello OC'ers! This is my first water cooling loop. I started putting this list together awhile ago, but life got in the way. Now I'm ready to start back up I'm looking for input to make sure I didn't make any rookie mistakes. My build is a Maximus V Formula mobo, i5-3570k, GTX 680 all in a HAF X case. I am going to cool the CPU, GTX680 and the the Thermo Fusion. I'm going to overclock the cpu and gpu also. Here is my parts list.
Radiators: Alphacool NexXxoS UT60 Full Copper Triple 120mm Radiator
Xtreme 200mm Radiator
Fans: Scythe Gentle Typhoon 120mm x 25mm Fan - 1850 RPM (D1225C12B5AP-15) - 3 in push
Silverstone Air Penetrator AP181 180 x 180 x 32mm Fan - (SST-AP181) - 2 in p/p
Phobya 180x180x20mm Fan / Radiator Shroud - Plexi x2
Water Blocks: XSPC RayStorm High Performance Acetal CPU Liquid Cooling Block - Intel
XSPC Razor nVidia GTX 680 Full Coverage VGA Block - Black - Reference Design (new style)
Tubing: PrimoChill PrimoFlex PRO LRT Tubing 3/8"ID 1/2" OD with 1/16" Wall - UV Red
Fittings: Bitspower Matte Black G1/4" Barb Fitting - 3/8" ID
Steel Spring Hose Clamp for 1/2" OD Tubing - Black
Pump/Resivoir: Swiftech Maelstrom 5 1/4" Dual Bay Standalone Reservoir w/ MCP35X Pump (Maelstrom-35X)
Fan Controller: Lamptron FC Touch - 30W - 6 Channel Aluminum Rheobus w/ Touch Screen - Black (FCT)
The Alphacool 120.3 rad will go in the top with the Gentle Typhoon AP-15 fans in push and the 200.1 Phobya Rad in the bottom/front of the case with the Silverstone air penetrator fans with shrouds in p/p. I already pulled out the bottom hdd cage to make room for the 200mm rad. I plan on running the loop starting at the outlet of the top 120.3 rad -> CPU -> Thermo Fusion -> Res/Pump -> 200.1 rad -> GPU -> and back to the inlet of the 120.3 rad. I will be using distilled water with a dead water additive.
After looking over Skineelabs and Martinsliquidlabs test results, I believe the radiator/fan combinations should provide more than enough cooling to moderately overclock the cpu/gpu. The pump should provide enough pump head and flow rate to get at least 1 to 1.5 gpm.
I should be able to easily run 3 to 6 Gentle Typhoon AP-15's off one channel of the fan controller and the the 2 Silverstone AP-181's off of another. I plan on running the pump from the CPU-Fan header since it is PWM.
I am looking for mental backup from experienced users. The only thing I see that may be questionable is the 200mm rad setup, basically since there isn't much data on it. The Phobya 200mm rad is designed for slow spinning fans and lower airflow. Is it possible to have too much airflow with the Silverstone AP181's? In theory the 200mm rad has a larger surface area than a 120.2 rad but I couldn't find any direct comparisons of the two. Thanks to everyone for taking the time to look over this setup.
