oh ok I see. I was under the impression that ram speed was just an independent factor. So the goal is a higer fsb speed with a lower divider? And if the ram says its rated at 400, does that mean your fsb will automatically run at 200?
You might take a look at this
link, I wrote it up a little while ago when I was trying to figure some of these things out. It tries to explain in more detail why and what you do.
No but based on what I said you could draw that conclusion. The reason you would rather run at 166, instead of less, is that the memory is accessed synchronous at or above 166 instead of asynchronously below 166. Synchronous access yields better performance. There are some numbers quoted in the above link.
No, most mobos will start out at either a fsb of 100 or 133 depending on jumpers or the bios. That is where you memory will start. The 200 rating (or DDR400) will only work at that level if you're able to set your fsb=200. Thus if you buy DDR400 memory and don't overclock it, you wasted your hard earned money.
