- Mar 6, 2009
haha wish I had a friend I could call over for when I needed a flashlight
Guy had to splice the wires since the 8-pin CPU line was too short. Here's Gigabyte's response.
LianLi is hardly main stream.
And bottom mounted PSUs are lame UNLESS running rATX format. then by all means bottom mount
Not to get too far OT in the Newegg thread, but do you have any empirical data or practical experience to backup the claim that the bottom-mount design is somehow inherently inferior?
Bah, my 1 and only sticky is now unstuck!
Well, you know the saying. It's better to have been stickied and unstuck than never to have been stickied at all.
Omg! I am soooooo reporting you for this obviously offensive line!
Just found this. On a Kingwin Lazer Gold 850W. Quite a nice PSU.
Here is one for my Motherboard...
Tech Level: somewhat high
Ownership: 1 day to 1 week
This user purchased this item from Newegg
Rating: 1 Star
"Catastrophe
Pros: The cmos reset button is very handy. I should know, I had to use it multiple times.
Cons: I was building a new rig using a Zalman 1000 watt PSU, 4GB of Corsair dominator RAM, an AMD Phenom II X4, and a BFG 9800 GX2 GPU. My first problem was that the board powered on, but wouldn't post. After a few hours of research, I deduced that the problem was that the BIOS didn't recognize the Phenom, so I spent some extra scratch buying a low end AMD CPU that would allow the board to post so that I could flash the BIOS. After updating the BIOS, voila, the board posted, and I was able to install the operating system. But that wasn't the end of my problems. When I installed the GX2, there was no video output. I checked and double-checked the BIOS settings, to no avail. The system posted, Windows loaded, (I could hear but not see it), but no video output. After changing the BIOS settings to onboard GPU always on so that I could see if the system was detecting the card (any time I exited the BIOS it caused a hang on restart by the way), it died. It won't even power on. I'm beyond disgusted
Other Thoughts: This board is overpriced to begin with, and the fact that I had to spend extra cash just to get it to post and it died shortly thereafter only adds insult to injury. My advice: steer well clear."
What a tool. Mine is running perfectly fine.
So just because your board is running ok and his wasn't makes him a tool
